Hello everybody!
I bought the Lite version and now I get extremely bad results compared to RC or Agisoft! I have already tested a lot of settings but the calculated STL are absolutely not comparable with e.g. Agisoft! Maybe you can tell me which parameters you use for an optimal result?
As an example, I scanned a handle from a pistol.
There are a total of 240 images. 60 frames per revolution and 4 different angles. When I go to the high resolution, Zephyr has problems arranging all the cameras. With the other programs this is not a problem at all!
You can download the pictures here:https://www.dropbox.com/sh/3pjdqn5e0...qrciP2DTbzGbmk
Here you can see the result with Agisoft!
I'm really excited to see what the STL looks like if you know Zephyr well!
