bad result with Zephyr Lite compared to Agisoft
  • Wolfgang
    • Feb 2020
    Hello everybody!
    I bought the Lite version and now I get extremely bad results compared to RC or Agisoft! I have already tested a lot of settings but the calculated STL are absolutely not comparable with e.g. Agisoft! Maybe you can tell me which parameters you use for an optimal result?
    As an example, I scanned a handle from a pistol.
    There are a total of 240 images. 60 frames per revolution and 4 different angles. When I go to the high resolution, Zephyr has problems arranging all the cameras. With the other programs this is not a problem at all!
    You can download the pictures here:https://www.dropbox.com/sh/3pjdqn5e0...qrciP2DTbzGbmk
    Here you can see the result with Agisoft!
    I'm really excited to see what the STL looks like if you know Zephyr well!
    • 690
    Hi Wolfgang - I've replied to your help ticket! Your dataset required specific settings to improve reconstruction - If you follow this tutorial on turntable processing you'll see even better results! https://www.3dflow.net/technology/do...for-turntable/
    Click image for larger version  Name:	zephyrWorking.JPG Views:	0 Size:	133.6 KB ID:	6050
