need a bundle of pictures to compare the function - "Check images Quality"
  • curieux
    • Oct 2018
    • 6
    Hi
    There is an option to check the picture quality . But I need some comparison picture to find out what qualtity my pictures have .
    Are there any database where I can download some picture with good quality to compare with my results ?
    regards
    Citing Roberto on the Image Quality Index Tool:
    - The quality index is not an absolute value. You will usually get higher values when the image resolution is higher, but a higher image resolution doesn't necessarily mean a higher image quality. It is very useful to find the worst/best images from a set of pictures taken with the same sensor/resolution.
    - The image quality index tool produces low/red values both for textureless and blurry areas.
    - It doesn't really distinguish the textureless areas from blurry ones since both of them will equally give you bad results in Zephyr.
    - It benefits from some of the algorithms that Zephyr uses during the reconstruction process to make a plausible quality estimation.
    ---- It will be more beneficial for you to share some pictures with us (using a file sharing service such as googleDrive or weTransfer) and we can give you some feedback on settings & image acquisition techniques
