Using pictures from a Insta360 One X
  • rupert
    • Mar 2020
    I would like to try and process images from my Insta360 One X. I've seen general photogrammetry advise that suggests it would be better to avoid the post-processed equirectangular images because the "stitching" process is going to distort the geometry and adds nothing useful to the raw camera output.
    The raw output from the camera is two fish eye images usually stored in a single bitmap but easy to separate into individual images. How would I go about importing those into 3D Zephyr? Presumably I would need the lens characteristics, which may or may not be in the raw bitmap EXIF (I can check).
    https://www.youtube.com/watch?v=_SDa2GfFCUg
    I hope this helps! Let me know if you have any questions!
    • rupert
      • Mar 2020
      Thank you Andrea. If you can import near-fisheye GoPro images I would have thought that the raw Insta360 images were similar. I've attached an example below:
        • rupert
          • Mar 2020
