plugin to revit
  • jose muņoz
    • Apr 2018
    • 13
    plugin to revit
    Dear Does the plugin to transfer data to revit work? Do you have any special settings to get it working?
    from Chile
    • 1364
    Hi Jose,
    you need to have 3DF Zephyr to install the plugin.
    Also, it hasn't been tested with the latest revit version, if that's the case you may need to rollback to the previous releases (2019 or 2018)
    • jose muņoz
      • Apr 2018
      • 13
      It has worked for me in Revit 2019.
      But not with all my examples.
      Additionally, when I generate the Blueprint, the information is not transferred as a solid, but only as a polyline.
        • 1364
        Hi Jose,
        you're right, surfaces were added later and the current plugin simply lists all the available drawing elements while it should only list polylines. We'll have that fixed for the the next update!
          • 1364
          On a side note, we have just pubished v0.92 of the plugin, which is compatible with Revit 2020, however you will still not be able to export surfaces, so make sure to uncheck them! The UI fix that will prevent selection will be in the upcoming Zephyr 5.0 patch.
