All options are greyed out
  • Jerry
    • May 2020
    I am running the pro trial version.
    I am trying to create a 3d model (with textures) from an e57 point cloud file.
    I can import the file by drag and dropping it in zephyr, however all export and generation options are greyed out how do i resolve this issue?
    • 1350
    Hi Jerry,
    in order to extract the mesh, you first will need to make the dense cloude structured. After importing it, right click it and select "make structured".
    Note that the file must embed the scan(s) origin, so make sure you are exporting that/those from the software that generated the e57 or you will not be able to structure it.
    Click image for larger version  Name:	makestructured.png Views:	0 Size:	11.0 KB ID:	6249
    Note that you will likely not get a very good texture using only bubbleview cameras. My suggestion is to integrate photos from a photogrammetry project to colorize your point cloud, like shown here https://www.youtube.com/watch?v=oT0C...ture=emb_title
    • Jerry
      • May 2020
      thanks for the explanation Andrea!
      I managed to get all my point clouds structured and i can extract the mesh now. And after extracting the mesh i can generate a texture.
      Only obstacle now is that there are 19 point clouds in my project, is there a way to extract them all as one mesh?
        • 1350
        happy to help!
        I assume the scans are already registered, in which case, you simply need to select the dense clouds (left click drag, in the same panel where you right clicked to make them structured - you will see the name of the element change color, or you can shift + left click) , right click -> merge
        Once the elements have merged, you can then extract a single mesh and eventually then, a textured mesh
        • Jerry
          • May 2020
          Thanks!
          This is exactly what I needed.
