Extract Frames from video file - Sample Rate - Formula
  • foxbat77
    • May 2020
    Hi, I'm trying to understand the function of the Sample Rate of the Extract Frames from video file workflow. My understanding seems to be backwards.
    If I have a 2 minute long video and set the sample rate to 1fps, it results in fewer extracted frames. If i set it to 2fps, it results in more extracted frames. I would think a larger sample rate, would result in fewer images.
    I'm looking how i can (by using a formula of some sort), target how many frames will be extracted. This is so that if I have a video of a certain length, I can try to use the entire video and stay under a certain amount of frames extracted. Is this possible?
    Thank you in advance!
    Hi foxbat,
    assume you have a video of 2 minutes (120 seconds).
    If you extract 1 frame per second you will get 120 frames.
    If you extract 2 frames per second, 240, and so on.
    That's as simple as that - regardless of the framerate the video is recorded.
    I hope this helps!
