Road to version 5.0 (Dragonfruit) - beta test thread
  • sam3d
    • 98
    #15
    I found that the exported .SCR orthophotos are rotated 90/180 degrees on import - seems to vary. I'm just using Draftsight so maybe true Autocad is fine but just thought it was worth mentioning. Otherwise they scale perfectly.
    • sam3d
      • 98
      #16
      On the Alignment screen the text at the top say "...marked as Control" Should this now be "...marked as Check" ?
      • sam3d
        • 98
        #17
        I still have an issue with portrait JPG images being rotated when adding CPs from images.
        Will send a sample set of images to support email address.
        v4.967 W10 Pro.
          • 1364
          #18
          v4.967 W10 Pro.
          that is actually the current behaviour in Zephyr , however Filippo added this contextual menu now expect it for the next beta release
          • sam3d
            • 98
            #19
            Thx Andrea; speedy solution Filippo
              • 559
              #20
              Changelog 4.968
              + SfM Urban preset rebalanced
              + Rotated photos are now also rotated in the control point selection dialog
              + Added full projection threshold control in the marker detection dialog
              + Several minor fixes
                • 559
                #21
                Changelog 4.969
                + Fixed deadlock in texture initialization
                + Improved texture blending
                + Fixed an issue that caused holes with out-of-core meshes.
                + Minor fixes
                  • 559
                  #22
                  Changelog 4.970
                  + Added popup on Scarlet for missing native format plugins
                  + Fixed image sorting when loading images from a folder
                  + Improved handling of invalid triangles (with no reprojection) during texturing
                  + Several improvements to texturing
                  + fixed a crash in texturing
                  + fixed a crash in LoD Mesh exporting
                  + fixed a crash during stereo point clouds merging
                  + fixed a crash during cuda check at startup
                  + fixed a crash related to key points animation
                    • 559
                    #23
                    Changelog 4.971
                    + Added a combobox to change control points to the edit control point dialog
                    + Several bug fixes and improvements(Texturing and Structure from motion)
                      • 559
                      #24
                      Changelog 4.972
                      + Improved points partitioning during stereo processing
                      + Fixed a crash occurring during texturing when selecting cameras for texture
                      + Added a photoconsistency and blurriness checks during the orthophoto creation
                      + Fixed an issue with photoconsistency and blurriness checks during the texturing creation
                      + Fixed an issue when loading old Zep with geoereferenced dense point clouds
                      + Fixed an issue when exporting .3dk from Scarlet
                      + Zephyr viewer will now reduce the gpu usage when the application loses window focus (user doing something else)
                      + You can now define a background color for orthophotos
                      + Minor fixes
                      • sam3d
                        • 98
                        #25
                        I noticed that saved orthophoto files that have a decimal point in the filename are missing the text proceeding the "." in any accompanying files.
                        v4.974 but not tried this in any previous version.
                        screenshot of files attached
