Window flips back to main view prematurely when entering control points from ima
  • Modeler17
    • Dec 2016
    • 27
    Hi All,
    In release 3.141 of Zephyr pro I am having a small issue adding control points from images. After select a control point in an image using the auto match button, the program flips the window back to the main window instead of staying on the control point window. This makes in necessary to manually switch windows in order to restore the view of the control point window and confirm the match and continue to work on the control point.
    Thank you.
    Hi!
    Thank you for the bug report! We introduced this bug while fixing another similar bug. Whoops.
    Right now there is sadly no fix. There is a workaround for this, which is to keep the control point selection window on another monitor if you're on a multiscreen setup or to shrink the zephyr window. We're really sorry about this.
    We are working on a small update (3.142) that will contain this and other minor fixes, which will hopefully will be released next week.
    Again, thank you and sorry for the incovenience!
    Andrea
    • Modeler17
      • Dec 2016
      • 27
      Thank you so much, Andrea.
