Hi all
I am totally new to 3d zephyr, so please apologise if I will ask a few dummy questions here...
My first question is about the worflow from photos to mesh.
My workflow is probably as it should be:
1) import photos -> generates sparse pointcloud
2) generate dense pointcloud
3) generate mesh
4) export mesh
At some point, I want to cut away everything that is not part of the object. I am assuming that the best moment to do that is directly after step 1.
But I don't really know the consequences of that:
- If I delete data after step1, does this affect the quality (in a negative way) of step 2 because some of the data I am cutting could have been beneficial for the algorithms of step 2?
- If I delete data after step1, does this affect the speed (in a positive way) of step 2, 3, 4?
-> does it change processing speed of steps 2,3,4 if I cut out the object of interest right after step 1?
-> would it be better for max quality to cut away things only after step 2 or step 3 (but not after step 1)?
Thanks for your answers!
J
3) generate mesh
4) export mesh
J
