Merging 2 pointclouds
  • josua
    • May 2020
    • 24
    After a workspace merge I happen to have 2 dense pointclouds (both of them were prepared carefully in the corresponsing workspaces before the merge, by cutting away unused areas and with control points). Now the question is: how to export both of them into just ONE mesh? I did not find any option to merge 2 pointclouds into one, or to export 2 pointclouds into one mesh.
    If there is no possibility to do so, the only option seems to create one pointcloud (or mesh) after the workspace merge? So all cutting away of unneeded areas in the workspaces before the merge is useless?
    Or did I overlook something?
    Hi josua
    You can merge two dense clouds by shift-clicking to select them both, then on the drop-down menu select 'merge'
    • josua
      • May 2020
      • 24
      Oh I did not know about the SHIFT-clicking! Thanks a lot!
      I recommend that you consider on your side how to make such "hidden" functionality visible and accessible through the UI.
