GPS information in DJI P4 RTK images not registering correctly
  • SBinary
    • Jun 2020
    When I import P4 RTK images into Zephyr Pro 4.530 the geotagged images are not read correctly. BUT when I am to start processing the images they are somehow geotagged. See screenshots.
    That is, I cannot specify the accuracy of the geotagged images (and make use of the RTK capability).
    SB
    • 1366
    Hi SBinary,
    you need to use 3DF Zephyr aerial in order to leverage GPS exif coordinates ( https://www.3dflow.net/3df-zephyr-feature-comparison/ ) - it seems like you are using 3DF Zephyr Pro, so if that's the case, you will not be able to directly load them from exif.
    • SBinary
      • Jun 2020
      Ah, ok. That makes sense. Thank you for the quick response!
