Masquerade
  • josua
    • May 2020
    • 24
    Masquerade
    Two things:
    1) The following is not clear when using the masquerade: is the Mask (indicated in red) the part that is processed or the part that is ignored?
    The UI does not really tell an inexperienced user if the mask is for the object or the background. Can you add this info somewhere?
    2) for a turntable setup, it is easiest to select a mask through a color in the background and then apply it to all images. But in fact the mask needs to be inverted for all images. Is it possible to first auto-apply the mask to all images through the color-option, then invert it for all images? I did not find a way to do it.
    Thanks for your help!
    Hi Josua,
    - yes, the red part is what is considered in the computation. You can click the top right corner to see a black and white representation (white=yes black=no)
    - i'm not sure I understand - if you have to copy the mask, there is a tool for that, otherwise you need to compute it manually anyways. Maybe you want a tool to apply the mask by color to all?
    Cheers,
    Andrea
