XML commands
  • magroni
    • Oct 2020
    XML commands
    Hi!
    Is it possible to add commands to an XML processing script to tell Zephyr to add control points, such as from coded targets or cameras, and then add commands to enter known distances between the control points, so that you can automate the scaling of models?
    Thanks!
    • 1364
    Hi magroni,
    that is not unfortunately possible at this time.
    For full automation, you may want to look into our C++ SDK www.3dflowengine.com which allows you to write your own, native software, powered by the technology behind zephyr.
    • magroni
      • Oct 2020
      Will do. Thanks!
