Reconstruction failing
  • edd335
    • Oct 2020
    Hi there,
    I have just recently downloaded Zephyr. I am experiencing some problems when it comes to the reconstruction phase. I am getting 6 pictures out of 50 photos reconstructed. I was wondering if anyone could have a look at my datasets and see if they could determine what the problem could be? I am using a go-pro HERO 7, a turntable and some sheets for these photo's. Behind the camera there is a large window. The object is a ps4 controller. I spent ages putting the foreground and background masks on to no avail.
    Have I taken enough photos? I cant manually control all settings (Shutter speed or aperture) on the GoPro so its possible some may have changed, could this affect it? I can keep the ISO balance the same on the GoPro but the light can clearly seen changing in the photos (Blue to orangy hue) due to the light from outside the window. I spray painted my turntable as I thought that it may have been a black background ruining my photos. I am currently using a laptop that doesn't have a GPU currently, would this affect my results? I am really out of my wits here. I have tried multiple things and watched all the necessary youtube videos so any help at all would be appreciated massively.
    Hi edd,
    can you please make sure you set that folder public, or send us in private at support@3dflow.net an accessible link? thank you!
    • edd335
      • Oct 2020
      Hi Andrea,
      I think I made it public. I sent it onto you privately also just in case.
        Hi Ed,
        thank you!
        When you move the subject it is no longer coherent with the background, so you will need masking in order toe xplicitly tell zephyr what you want to reconstruct
        Masking for turntable   Welcome to the 3DF Zephyr tutorial series. In this recipe, you will learn basic and advanced masking techniques that applies to a turntable scenario in seven steps to Turbocharge your Turntable. While we have already introduced masking with Tutorial #3, this tutorial is … Read More
        Try also getting closer to your subject when taking the photos, as you're currently not using a lot of the available frame.
        However, your subject is also difficult as it is simple plastic - while the front has the camo pattern, the rear is much more difficult so you should probably consider using advanced techniques (or simply dirtying it if you don't care about the texture color) such as a projected pattern https://www.youtube.com/watch?v=E06k...ture=emb_title
        If this was a test to get started, i suggest starting with an easier subject (eg. a rock or a tree stump), otherwise if you need to scan that, you will need more photos and possibly using the advaced techniques mentioned above
