Good day,
There is the well known way, how we can marge drone + ground image sets in Zephyr, but I was wondering, that did I missed some new ways, or it remained the same? As:
- from drone image set - generating sPC - dPC - mesh - export with control points
- from ground image set - generating sPC - setting up control points - importing the exported drone mesh - converting the imported mesh to point cloud and aligning them by using the control points.
Do we have any new ways? Or that is the correct workflow?
Do we have any new setup options to force Zephyr to merge the two image sets in one project from the start? Even if they would create two separate non aligned point clouds, so I would be able to merge them by control points, but at least inside the same project from the start?
