3DF Zephyr 3.300 beta release
This topic is closed.
    the Beta for the upcoming 3.300 release is ready
    If you already have a beta key, you're already set. If you don't, and would like to help us in betatesting 3.300, please post here or contact us directly via email.
    v.3228-3229 changelog
    • Final bug fixes and translations updates
    v.3227 changelog
    • Improved bundle adjustment during workspaces merge with control points
    • Improved optimize camera parameters and alignment to control points worflows on failure (problematic cameras are now detected and can be removed from the dialog).
    • You can now define the up vector by choosing at least three control points (without know 3D coordinates).
    • Rematching can now be cancelled or paused during bundle adjustment and alignment steps.
    • Zephyr can now be deactivated also if you are offline.
    • Added hint when adding control points with 3D coordinates but without any 2D coordinates.
    • Several minor bug fixes, thanks for the feedback!
    v.3225 changelog
    • Stereo improvements and preset balancing
    • Photconsistency mesh optimization speed improvements
    • Improved point cloud structuring and mesh computation for laser scan point cloud.
    • Selection tools improvements
    • Camera positions can now be added as control points
    • Stereo texture can now been unstructured
    • Added image overlap in the processing report
    • Gizmo can now move entire objects only in rendering
    • Added chinese language support (beta)
    • Several bug fixes
    v3.222 changelog
    • Sparse point cloud generation improvements ( rematching accuracy improved )
    • Stereo point cloud generation improvements ( speed and accuracy )
    • Fixed a bug during mesh generation (small parts are reconstructed better now)
    • Fixed a bug in stereo point cloud generation
    • Improved sketchfab upload Improved cloud comparison tool
    • Log and System info are now available as separate window from the progress bar
    • added mesh filtering on selection (laplacian, bilateral, retopology)
    • added triangle selection filtering by connected components
    • elements name are now customizable (i.e. create a control point with "CP" label rather than "Control Point")
    • Added virtual line from control point to point
    • Added clear cache button and additional memory checks
    • Update Ogre Engine
    • Added option to toggle rendering "fog"
    • Impoved rematching phase
    • miscellaneous bug fixes
  • Roniswid
    • Jun 2017
    Ciao Andrea: I'd like to be added to the 3.300 Beta please.
    Ron
      Hi Roniswid,
      I've sent you a pm with the beta key. Happy testing!
      • GeoDrones
        • Jun 2017
        Hi, I would also like to get a beta key. The previous one I have doesn't work with this version.
          Hi, I've checked and reset your old key. There was probably a pending activation on another machine. Please let me know if it works now!
          • 3dscanreality
            • May 2017
            • 25
            been using since yesterday and tested with a small dataset, around 50 cameras on a panel and it handled really smooth
            today, i've used with a larger dataset... around 250 images 18mpx each and it started to struggle a bit... in the first two tries it crashed the software.. needed to force to quit it and then on the third attempt is was ok..
            this is my feedback until now..
            ps: as a Lite user, I really love having all the parameters to use amazing software
              did you send the crash report? If not, can you please send me a log of the reported crash, so that we can investigate? thanks =)
              (thank you for the kind words )
              • 3dscanreality
                • May 2017
                • 25
                it didnt appeared any dialog box to fill the crash report... it simply froze and had to force quit the software... now, i don't know if it is because of my pc, but in the lite version even with more images this didn't happened yet..
                • Juriy Radkov
                  • Jun 2017
                  Hi, can I also get v3.3 for test, please? I would also like to know if there is a way to test your s/w with more than 50 pics as I am trying to evaluate its results compared to other products in order to ultimately purchase a high end license (I am pretty happy with export disabled or similar limitations)?
                  Best Regards,
                  Juriy
                    3dscanreality hm, odd, the crash report should always appear if you could check your log directory and find the crash related log and forward it to me, it would be super helpful! thanks!
                    Juriy Radkov absolutely! i will contact you at the email you used to register to the forum our trials are only time limited, but all features are available, exporting is important too!
                    • 3dscanreality
                      • May 2017
                      • 25
                      i'll check it as soon as i get home
                        3.225 on its way =)
