hole filling?
  • roger johnson
    • Nov 2020
    • 61
    hole filling?
    I am attemptng to create a slice of an existing mesh using the bounding box editor and mesh extraction.
    This leaves the sides of the slice without mesh.
    Should I be able to fill the missing sides of the mesh using selective mesh filling?
  • roger johnson
    • Nov 2020
    • 61
    I notice that there was a similar query almost couple of years ago..
    using a plane cut mesh...
    although I couldnt see the image to check
    however andrea reported it as a potential enhancement. See
    I like the way a plane can be used to cut an object in a clean way. However it looks that it is very difficult to close the hole without having zigzag surfaces. What am I doing wrong?
    I have looked at and tried meshmixer but cant seem to get the erase and fill option to fill the intended 4 bounded sides..
    Are there any other free editors that might do the job?
      Hi Roger,
      After performing the cut, I suggest using the "Fill holes watertight" function under "filters". The filter should fill all the holes in the mesh.
      Best,
      Roberto
      • roger johnson
        • Nov 2020
        • 61
        Thanks for suggestion. Will keep in mind.
        I think the plane cut method showed me the way and then use the "fill selected" option of the " fill holes selected" dialog box.
        Its not as predictable as I would have expected but it seems to be what I need so Im happy enough
        • roger johnson
          • Nov 2020
          • 61
          Probably spoke too soon...
          the predictability of the fill algorithm seems unknowable ...
          which I cant quite understand having applied it immediatly after a cut operation...
          so it seems it should be quite simple
          • roger johnson
            • Nov 2020
            • 61
            Well I took your advice and used the watertight option .....
            and it worked ! (amazed) athough the texture of the "new" walls is still a mystery
            A bit more zephyr documentation would be useful
            but in any case thanks again
