masking thousands of pictures
  • gimly1992
    • Jun 2017
    Hi!I have about 3000 pictures that I need to mask. I have two cameras mounted on top of a car.I realize now i should have placed them better:the car roof is visible in every images.Manually copying/pasting the .bim files and then renaming them is not a practical solution.
    Please advise!
    Hi Gimly,
    you can copy previously generated masks using the "copy to all" function.
    please note that the "copy to all" wil apply to all images in order as shown in the right side list. Meaning, if you have listed photos 1,2,3,4,5, select number 3, mask it, and then "copy to all", the masks will be copied to 4 and 5. Use that to your advantage =)
    • gimly1992
      • Jun 2017
      Thanks!!!!
