Low quality of 3d model created by 3d zephyr in other software
  • AbbasA
    • Feb 2021
    • 14
    I saved the 3d model of a field in ".ply" format using 3d Zephyr software. However, when I use other software (such as MeshLab) to show the file, the quality of the 3d model is so low compare to 3d Zephyr software (attached images). Is there any solution to show the 3d model without reducing the quality in other software?
    Thank you,
    Abbas
    Hi AbbasA
    If the dataset is georeferenced (GPS) then Zephyr automatically saves the mesh vertices with double-precision (no rounding errors etc...) - LOTS of software doesn't support double precision data, so to import successfully it needs to be converted to a Local Rendering Reference System. (Maya, Meshlab etc... etc...).
    You can select local rendering reference system on export, or in the workspace you can click this button:
    • AbbasA
      • Feb 2021
      • 14
      Thank you so much for your help. It works.
      Abbas
