Set initial camera view
  • nenadv
    • Sep 2019
    Is there a way to set the initial view on the playback? I cannot find it in the docs.
    • 1350
    Hi nenadv,
    what do you mean exactly? I assume you refer to the animator in zephyr and you are asking how to play from a specific, predefined, keypoint.
    If so, simply define your camera path normally, then right click the keypoints you want to start playback from, then select "play from here"
    If not, could you please elaborate your question a bit? Thank you!
