Question about surface area/volume measurements
  • AbbasA
    • Feb 2021
    • 14
    Do I need to close the 3d object to measure its surface area or volume?
    Thank you,
    • 685
    Hi AbbasA -
    You don't need to close a 3D model for area calculation, however, please note that if you close a hole on a surface your area calculation will be greater than if you left the holes in.
    Volume automatically fills holes (at least the ones it's able to fill) and can take a bit of time if you have lots of holes to fill. You might want to do this manually for more control. A new unstructured mesh is created in addition to the mesh you are measuring the volume of.
    • AbbasA
      • Feb 2021
      • 14
      Thank you for your help.
      Abbas
