Only 11 of 48 pics recognised -> rookie question
  • Michael
    • Mar 2021
    Hi all,
    I am completely new to Photogrammetry, so please bear with me if this is a dumb question:
    I have started the program, all setting within 3DF were left standard and I just clicked through without changing the default settings. Now I imported my first project (48 pictures) which I photographed using a 3d scanner (Openscan Classic from Openscan.eu site).
    This being said, the camera is steady and the scanned object moves around in front of the camera, so this is where my questions begin.
    The result is like the screenshot below. Besides that only 11 of my 48 pictures are recognised, I do not know why the camery positions are lined up as shown below... how can I avoid that (camera position is not correct as I would assume from below output) and tell that all 48 pictures should be processed...?
    TIA!
    Michael
    • 704
    Hi Michael -
    Without seeing the source images it's hard to say what exactly is going wrong, but my suspicion is that you haven't masked out the background of your images, and that 3DF Zephyr is finding strong feature matches in the background of your photographs. These feature matches override your subject feature matches and pile all your images on top of eachother in the viewport.
    Masking is a great way to isolate relevant data. Here is an article you might find helpful: https://www.3dflow.net/technology/do...for-turntable/
    • Michael
      • Mar 2021
      Hi cam3d,
      thanks for pointing the mask feature out. This helped a lot!
      I ran over the tutorials and have now a slightly better result - but far away from being perfect :-(
      I will try to explain what I did with a small sample:
      first photo shows the object whith turns around - not the real object of course :-)
      second shows how I did the masquerade (I did it for each photo separately to be more accurate).
      Calibration was done automatically (GT-i9300 which is a Samsung S3 mobile)
      Everything else was left at default.
      Third photo shows intermediate result just before I hit run.
      fourth photo shows that only 12 of 48 photos could be processed - which is far too less.
      last photo shows the outcome, which is not the complete object. May be the pink surface being to glossy?
      Any hints on that?
      TIA!
      Michael
        • 704
        Michael I'm glad the masking helped!
        Something to note is that your subject is feature poor (it's a smooth plastic surface with very few distinct features for Zephyr to work with) - If you were to add some features using a powder (talcum powder can be good!) then you should see that your 3D reconstruction improves a lot!
        • nthnlwilbourn
          • Mar 2021
          Originally posted by cam3d
          Hi Michael -
          Masking is a great way to isolate relevant data. Here is an article you might find helpful: https://www.3dflow.net/technology/do...for-turntable/employee monitoring software
          thanks a lot, the article is really helpful. I have seen similar problems with image recognition many times already, I hope to fix it in the near future
