compile error about FlowEngineFreeLinux64_5019
  • letian
    • Apr 2021
    When I built FlowEngineFreeLinux64_5019 on Ubuntu 16.04 as the following link says ?
    file:///media/zeng/work/FlowEngineFr...tallationLinux
    Errors occur as shown in the following:
Name:	Screenshot from 2021-04-27 16-11-08.png
    Could you please give me a hand?Thanks very much!
  • letian
    • Apr 2021
    Dear FlowEngine team?
    I downloaded the FlowEngineFreeWin64_5019 on windows10-64bit system for free. When I ra? errors occur as follows?
    Severity Code Interpretations File Line
    error(Activity) E0035 #error instruction: "Unsupported Platform!" Common.h 92
    error(Activity) E0020 Undefined identifier "ti" Common.h 143
    I do not know how to solve this problem. Could you please give me a hand?Thanks very much!
    Yours sincerely,
    Letian Zeng
      you are missing imagemagick
      make sure to compile it with the options described in the readme
      for example
      apt-get install -y libpng-dev libjpeg-dev libtiff-dev && \
      tar -xvf ImageMagick.tar.gz && \
      cd ImageMagick-7.* && \
      ./configure --with-quantum-depth=16 --enable-hdri=yes CXXFLAGS=-D_GLIBCXX_USE_CXX11_ABI=0 && \
      make -j8 && \
      make install
      then make sure to run ldconfig or have imagemagick point to the right library if you have multiple versions installed
        You must run cmake and target x64 architectures, also I suggest using VS2019
