Hello, first try with errors
  • martinhgps
    • May 2021
    Hi everybody, Im new here.
    I shot a video from a sculpture fron a Dog and tryed to process it wit 3d Zephyr but did not worked. I used default values. There is too much to have in mind.
    Here is the input data
    Can you help me? Thank You! Regards, fMartin (from Argentina)
  • martinhgps
    • May 2021
    Hi everyone, capturing small objects, which method is best?
    a) Use a turn table and keep the camera still
    b) Keep steady the object and move the camera around taking pictures?
    Thank you !!!
    Regards
      Hi Martin
      Welcome to the forum And thanks for sharing your source data.
      I'd recommend starting with photography rather than video, as video will almost always give a lesser result, all other things equal.
      Your subject is not ideal for reconstruction with photogrammetry, and I recommend sprinkling flour or talcum powder on the surface to give it some features for Zephyr to work with.
      Regarding your question about methods: Both are valid, however option B will be easier if you don't have photographic lighting etc..
      Here's a tutorial on turntable basics: https://www.3dflow.net/technology/do...for-turntable/
      I hope this information is helpful!
