How do I keep the leaves from interfering
  • Dry3210
    • May 2021
    There was a tree near the left side of the house and the green from the leaves is showing up as though the siding is green in spots.
    I tried it regular and then I also tried masking out any part that overlapped and got the same results
    3D reconstruction using 413 images of the William Tennent House - William Tennent House - 3D model by megandanphotography
    Hi Dry3210 - Welcome to the forum! It looks like you've made a mesh with only vertex colours. If you create a textured mesh you can select which cameras you want to use for texture projection. When taking photographs try to keep your line of sight as clear as possible - Leaves moving on a tree in-front of the subject you wish to capture will be quite difficult to isolate and filter out, so best you try and avoid them as much as possible.
