Scaling of 3d model to be as the same size of the original model
  • Mostafa kamel
    • May 2021
    Hello
    please i need a method to calibrate and scale the 3d model obtained by zephyr to be as the same size of the original model
    notice: i am working with small objects and i need high accuracy in mm or even fractions of a mm
    thanks
  • ale47p
    • Feb 2020
    • 13
    if you need that accuracy it is not possible without having the object in your hand...you have to measure and scale it
      Hi Mostafa kamel - For high levels of accuracy it's recommended to use control points in the full version of 3DF Zephyr.
      We have an explanation of accuracy and a calculator to help approximate your level of accuracy which can be found here: https://www.3dflow.net/technology/do...sion-accuracy/
      Accuracy is a bit of a tricky subject to quantify - You also need to account for any human inaccuracy when selecting control points.
      Control points and distances: https://www.3dflow.net/technology/do...es-3df-zephyr/
      Free/Lite approximate scale: http://support.3dflow.net/support/so...-free-and-lite
      • gravy3d
        • Apr 2022
        Free/Lite approximate scale: http://support.3dflow.net/support/so...free-and-lite
        Hi cam3d! Thank you for your advices, they are very helpful. Could you tell me please, to what degree of accuracy is it possible to scale the 3D model? Does it make sense to talk about fractions of a mm or is it rather impossible?
        • EgorKonovalov
          • May 2022
          Hello.
          Can I orient and scale the world with the exact coordinates of the three cameras? How to do it?
            gravy3d Sorry I didn't see your message until now - The degree of accuracy is dependent on hardware and operator skill, you can reconstruct microns with an electron microscope or meters with an aerial survey.
            Egor You can orient and scale using control points - more information here: https://www.3dflow.net/technology/do...es-3df-zephyr/
