What is the highest resolution image zephyr can process
  • CG-Guy
    • Apr 2018
    • 151
    Thanks for reply
    • 688
    Hi CG-Guy - Do you mean input or output?
    Input: Pretty much anything if your computer can handle it :-) I feel obliged to mention that resolution does not equate quality, and lighting/consistency between images is far more important.
    Output: 32768*32768px - This is not recommended for general use as 32k is an insanely big single image - Much more efficient to process a multi-texture of 8/16k images- Using multi-texture means you can have a TON of resolution with much better performance in most scenarios :-)
    • CG-Guy
      • Apr 2018
      • 151
      It was input - thank you
      2nd question is how does it assign multiple textures to the mesh if I choose that option? Does it do a sub material like 3ds max so the mesh is not seperated when processed?
      I typically only use 1 4k texture with 1 uv space but my next subject matter is 24ft long and will require multiple uvs and output textures
      Thanks for response
        • 688
        The mesh remains intact and is not subdivided, the UVs are spread across multiple UV tiles following the UDIM Workflow.
        • CG-Guy
          • Apr 2018
          • 151
          Perfect- I've done udims before had like 29 of them on an object
