Is it possible to orient images that did not work in the first project pass?
  • wrecktech
    • Aug 2021
    I have a project of a large house that I captured by going all around the house at ground level. The images at the back of the house were oriented and a sparse cloud was created. How can I get the program to orient the images from one side of the house and incrementally add all of the rest of the house? Can I work with the images from the first set or do I need to create a new project from the images that worked from the back of the house and keep adding successive images.
    wrecktech - Welcome to the forum. I'd recommend capturing everything then processing everything in the same project, rather than incrementally adding parts. If you can share the data (public google drive download link or similar) we can give some feedback on your image acquisition and processing settings.
    • wrecktech
      • Aug 2021
      Unfortunately I cannot post the files as they contain GPS data that would identify the location and point to the incident involved. I will try your suggestion and work with control points to add non-oriented images to the project.
