export formats
  • roger johnson
    • Nov 2020
    • 61
    #15
    Apologies . Ive sent a copy which is 8192 x 8192 png via we transfer........... fingers crossed.
    BTW Im still unsure if the textured phase is essential .
    Given that the non textured mesh appears cleaner, isnt the mesh .obj good enough ...
    and then use a free obj to glb convertor ?????
    • roger johnson
      • Nov 2020
      • 61
      #16
      Anyway...........
      Iv have tried what you suggest and set the textured mesh to 128,000 vertices, run the textured mesh phase again and then exported it as.GLB and JPG
      It has produced a 34Mb GLB file Textured_mesh_2 which seems to display better image when opened with 3D VIEWER.
      The JPG file is around 8Mb
      So it looks like the final format generated successfully.
      Great !
      Cant exactly say why but now I can get on with my NFT experiment
      Cheers
        • 704
        #17
        Hi again roger johnson - I looked at the new texture file and it appears to have different UV coordinates when compared to the .OBJ file. This implies that the texture sent through was build for a different version of the 3D model.
        Glad to hear my suggested specifications worked for you! Good luck with your NFT experiment :-)
