Question - Ortographic view mode
  • 3dscanreality
    • May 2017
    • 25
    Hi there,
    I was wondering if in orthographic view (camera) is possible to go deeper on the model before it starts to clip... in other 3d applications there's also this deal... "nearest clipping distance".. usually my models are quite small and i have some trouble aligning them on to the surface because as I go closer to the model it starts to clip...
    thank you very much
    Hi!
    there is no clipping distance in the options, i'll talk with Roberto (he's out of office this week) and we'll see if it's possible to add it in the next release
    In the meantime, i suggest you use the the vertical alignment tools in case you missed them, i don't like using the gizmo
    • 3dscanreality
      • May 2017
      • 25
      Hi!
      thank you
      that would be awesome
        We are adding that feature in our internal release as we speak
        While we develop the next release (it's gonna take a while, as 3.300 is pretty fresh) however, you can also scale up the model rendering using the gizmo as a workaround
        • 3dscanreality
          • May 2017
          • 25
          thank you
