Import OBJ and project photos to re-texture
  • KenmoJr
    • Jan 2022
    • 89
    I'm still debating whether to purchase 3DF Flow Lite vs Metascape Standard or use RealityCaptures free version.
    One thing I really like in Metascape Standard as I play with their 30 day trail is the ability to bring in a low poly model which I retopo'd in 3DCoat or Blender, is the ability to import it into Metascape (or Reality Capture) and re-texture the low poly model with your photos.
    I see in 3DF Zephyr under File there is an option to Load Model which appears to be the same as Metashapes & RealityCapture's Import Model option. However I can not figure out how to re-texture with your photos. When I load the retopo model in Zephyr it clears out all my cameras and projects, workspace, meshes, etc. How do I do re-texture a model which has been retopo'd in another app in Zephyr?
    Having a 30 day demo in Metascape is a big plus over 3DF Zephyrs 15 day trial. Also Metashape does not have the 500 photo limit. Other than that I find both Metascape and Zephyr to be pretty comparable.
    I also got much better results with my car photos in Metascape and RealityCapture vs Zephyr. That said I still prefer Zephyr or Metascape over RealityCapture.
    Many thanks.
    Kenmo
    • 1358
    hi Kenmo,
    the load function will just load the model to view it / use tools on it.
    You need to use the import -> import mesh with uv map (not available in the free edition) in order to reproject textures on an edited mesh.
    You can find the tutorial here https://www.youtube.com/watch?v=rvXBzw2PVMU
    When you are ready, feel free to reach out to support@3dflow.net if you need additional trial time, we are happy to extend trials whenever required.
    • KenmoJr
      • Jan 2022
      • 89
      Is the import mesh available in the version of 3DF Zephyr which sells approx for $200?
        • 686
        KenmoJr - Yes you can import meshes into the Lite version of 3DF Zephyr.
        • KenmoJr
          • Jan 2022
          • 89
          hi Kenmo,
          I can? I thought I did when I posted a few times on this very forum about the 15 day limit was not a good useable option especially with all the other distractions and commitments one has in daily life. I never received any replies about this until you were kind enough to reply.
          Thanks very much for your reply...
