decimation rules
  • roger johnson
    • Nov 2020
    • 61
    decimation rules
    nother dumb qustion!
    how does decimation essentially work ?
    does it decimate those areas of the obj that are basically out of focus?
    leaving the areas with the best quality eg surface scan ???????????
    Hi roger johnsonPreserve the boundariesConstraint distances from the input mesh: the decimation process uses an extra constraint for selecting the vertices to be decimated, which is based on the distance from the starting mesh.
    Here's an informative article on the subject of decimation in general: https://odgy.medium.com/mesh-decimat...t-95245c4b5f52
    • roger johnson
      • Nov 2020
      • 61
      many thanks
