Exporting issue in 3DF Zephyr Lite 3.300
  • stevijn
    • Jul 2017
    Hi guys!
    im running into a problem with exporting my first test in the 3DF Zephyr Lite trial.
    The exported mesh seems to get distorted with these cube type structures, opposed to the smooth surface from Zephyr. attached a screenshot.
    Do you have any idea what i might be doing wrong? perhaps there is limited export functionality in the trail version? you help would be greatly appreciated! thanks in advance!
    Kind regards,
    • 1386
    Hi Stevijn,
    sorry to hear about your issue!
    The trial version is only time limited, there are no limitations whatsoever.
    What are you viewing the mesh in? This kind of artifact is usually seen when dealing with geographical coordinates (for example if your device embedded GPS data in the exif) and if the external viewer doesn't support double precision coordinates.
    Try selecting the "Local Rendering Reference System" option in the export settings.
    If the problem persists, could you share the images and the zep file with me for further analysis ?
    best regards,
    Andrea
    • stevijn
      • Jul 2017
      Hi Andrea, thanks so much for your quick reply! this fixed my issue.
