Need some tips
  • DonSenilo
    • Jun 2022
    Need some tips
    Hello
    I'm trying for a few days now to get a usable result but without luck. Please take a look at the picture - I think the problem are the main colors. I tried different backgrounds and undergrounds.
    Here is an example for what I get:
    Hi DonSenilo,
    from the screenshot it looks like you have not masked your images. If you are rotating the subject it is extremely important that you mask them, as zephyr has no way to know i fyou want to reconstruct the object or the room. Moving the subject makes background and foreground incoherent, so make sure to either move around the subject, or mask the images after taking the photos.
    you can find a short videotutorial here
    Additionally, your subject is certainly not easy as it lacks texture, being mostly plain surfaces. Consider dirtying the surface, if you don't need the texture.
    • DonSenilo
      • Jun 2022
      Hello Andrea
      Good point. I will try it. Thank you very much.
