About the deformation of the mesh when importing Blender
  • takumiLN
    • Jul 2022
    When I export a 3D Zephyr texture mesh with obj / fbx and import it with Blender, the shape of the mesh changes.
    Is there any way to solve this, such as export settings?
    Hi takumiLN - If the dataset is georeferenced (GPS) then Zephyr automatically saves the mesh vertices with double-precision (no rounding errors etc...) - LOTS of software doesn't support double precision data, so to import successfully it needs to be converted to a Local Rendering Reference System. (Maya, Meshlab etc... etc...).
    You can select local rendering reference system on export, or in the workspace you can click this button:
    Click image for larger version  Name:	image_1967.jpg Views:	0 Size:	3.1 KB ID:	8254
    I hope this helps!
    • takumiLN
      • Jul 2022
      Hi cam3d.
      I click Reset Local Rendering Button,
      It was displayed correctly!
      Thank you so much!!
      • KenmoJr
        • Jan 2022
        • 89
        I hope this helps!
        That is good to know. Many thanks.
