Can I cut the mesh smoothly?
  • kafkaf21
    • Aug 2022
    Us there a way to cut the mesh smoothly?
    When I use the selection tool they select the polygons, leaving jagged edges like this:
    I need to cut it smoothly like this:
    If this cannot be done in 3df, can it be done in blender and if yes, what is the best, and easiest way to achieve a smooth cut??
  • CG-Guy
    • Apr 2018
    • 151
    3ds Max uses the "slice" modifier - maybe blender has something similar like this youtube
    Hes using a cube to cut a cube, but you can use a 2d plane to get a slice effect
      Hi kafkaf21 - The selection tool selects the mesh polygons which is why you see the jagged edges - It's currently not possible to achieve what you are after in Zephyr.
      I'd recommend checking out Plane Cut Tool in Meshmixer (https://www.meshmixer.com/) (Tutorial: https://www.youtube.com/watch?v=BaNGNgTKSZE)
      • danwillington
        • Sep 2022
        Hello sir, I'm looking for tools or assets that can cut mesh smoothly.
          Hi danwillington - See link above to Meshmixer + Plane Cut Tool tutorial :-)
            Saw this thread only after cleaning it up from some spam.
            You can also use the cut with bounding box tool in zephyr. That will create new polygons from the intersection, creating a clean cut like requested, so you don't need to exit zephyr to achieve that
