model generation settings
  • Sayeed khan
    • Oct 2022
    • 23
    what setting would you suggest me for creating the 3d model
    about my data set
    contains around 2000-3000 images
    images are taken from drone
    these are images taken from drone of a tall building starting from top to bottom
    5472 x 3648 pixels
    each image is of around 8-10 Mb
    following this pattern ?
    should i use default or category ariel / default / vertical structure?
    presets : default / deep/
    Sayeed khan I recommend using the General Default camera orientation settings, and if they aren't successful try switching to Vertical Structure Default.
    Different datasets will have different processing requirements, but as a general rule, if you use the defaults and adjust your image acquisition to work with those settings, you'll ultimately be capturing better data which requires less processing power to achieve the results you want.
    • DMG
      • Sep 2022
      • 12
      Something which dawned on me recently was that because the Default settings are much faster than the deeper processes, if I have a problematic dataset, it's still usually faster to align as much as I can on Default, then add the images which didn't align using the deep scan.
      It seems to work fine doing it this way, and is certainly a heck of a lot faster than processing the entire set of images at high quality.
