I'm having a lot of difficulty getting a good scan of a thin object using 3df Zephyr. I've looked at some of the articles on the forum, such as this one, but I still have been unable to achieve good results:
https://www.3dflow.net/forums/forum/...-a-flat-object
I welcome suggestions.
For this project, we are scanning Viking weapons in order to get detailed measurements of these objects to use for modeling the physics of the weapons when they are wielded.
I've been able to get excellentd scans of Viking spearheads and axeheads. But a good scan of a Viking sword continues to elude me. The resulting model is good over most of the sword, except at the point, where the object is both thin and small. The two flat sides of the sword are well modeled, but they don't meet along the edges or at the point. It is as if the front and back flats of the sword were two sheets that were imperfectly aligned and then attached to one another - they are offset laterally by a few mm.
My work flow:
1. I've created a jig for the sword, so the camera, lights, and contrasting color background are fixed, and I can rotate the sword around its long axis to get pictures around one orbit, then move the sword along its length to get the next orbit, and so on, along the length of the sword.
2. The historical sword (which I can access for my tests only rarely) has plenty of surface texture and needs no treatment. The modern replica I use as a stand-in is shiny, so I dust it with white powder to dull it, then apply blotches of contrasting color chalk dust to create a random pattern over the surfaces.
3. I take many photographs, with closely spaced photos at the edges, and more widely spaced photos of the flats. I also shoot oblique shots all around the point. I'm using the Lite version, so am limited to 500 images, and I aim to get that many images of the entire sword.
4. I mask the images in Masquerade to eliminate the background, leaving only the sword.
5. I process the images with advanced settings, with all the parameters set to the highest level.
Generally, all the cameras are accepted except for the edge shots. The sword, on edge, takes only a small part of the camera frame, and I presume there is simply no detail to capture and match with other views. Inspecting the images from the camera, they seem to be sharp and detailed with sufficient depth of field
I welcome suggestions or recommendations. Thank you.
My work flow:
