Is there a way to import alembic file ?
  • Mxicklejx
    • Jan 2023
    Hello, I was looking for a way to import aligned cameras from another photogrammetry software to zephyr, however i can only get alembic .abc file and it doesnt seem like zephyr have import option for it.. Is there a way to do it ?
    you can import cameras in text format in zephyr either as txt ( XYZ, XZY, opengl, etc) in two files (externals and internals) or - better yet - you can use the .xmp workflow.
    Please note camera import is available in the full version of 3DF Zephyr only. Either use the "load photos with know parameters" function (if you are using the two internals and externals files approach) or use the .xmp file workflow with an .xmp per camera.
