Blender obj import doesn't work
  • josch76
    • Mar 2023
    A successful rendered object in Zephyr looks very strange and isn't usable in Blender. Both software current version. Do you have any idea?
    Regards
    Jan
    Hi josch76 - If the dataset is georeferenced (GPS) then Zephyr automatically saves the mesh vertices with double-precision (no rounding errors etc...) - LOTS of software doesn't support double precision data, so to import successfully it needs to be converted to a Local Rendering Reference System. (Maya, Meshlab etc... etc...).
    You can select local rendering reference system on export:
    • MarcinMango
      • Mar 2023
      I have a similar problem after the last update, but in my case the imported data from 3DF (obj format) does not appear on the screen in Blender. I never had such a problem before the last update.
        Hi MarcinMango - This video explains how to focus on different things in Blender - https://youtu.be/8hHSPhgWSV0
        If you can't see the model in the viewport at all, select in the 'Scene Selection' (top right) and proceed from there.
