How to activate 'ShapeFromSilhouette' in Default.xml?
  • nkelsey86
    • Mar 2023
    • 8
    Ciao! I love this app so far, it is amazing.
    For simple smooth objects (vase, coffe cup, etc) I think the Silhouette feature would work great, but I cannot get it to work.
    I am trying to activate the 'ShapeFromSilhouette' feature by setting values in the Default.xml.
    I do not see specifically how this can be set. I hope that it is possible to set this when sending to the 3DFlow processor.
    Currently, I have been trying combinations of this:
    <Category name="Stereo">
    <Entry key="ShapeFromSilhouette" value="On"/> <-- should this be 'On' or 'true' or something else?
    <Entry key="ShapeFromSilhouetteDiscretization?" value="medium"/> <-- should this be something else?
    <Entry key="HyperplaneMatching?" value="On"/> <-- should this be 'On' or 'true' or something else?
    </Category>?
    I am including '_masked.jpg' versions of these files also (target in white, background in black).
    Does this look right?
    Thanks for the help,
    - Nick
    Hi Nick,
    The value "UseShapeFromSilhouette" and "UseShapeFromSilhouetteForInitialization" can be either set to "1" (true) or "0" (false).
    I suggest setting UseShapeFromSilhouette -> 1 and UseShapeFromSilhouetteForInitialization -> 0.
    The other value you can set are:
    "ShapeFromSilhouetteLooseness" -> value from 0 to 100 (approximation factor, depends on your masks)
    "ShapeFromSilhouetteNumberOfBins" -> values: 256, 512, 1024. 256 equals low, 512 medium, 1024 high
    Please note that you don't need the hyperplane-matching (for standard stereo) as it has been dropped with the latest versions.
    Best,
    Roberto
    • nkelsey86
      • Mar 2023
      • 8
      WOW - thanks so much for the quick response! I appreciate it!
      • nkelsey86
        • Mar 2023
        • 8
        The job keeps failing on me though.
        Here is my Default.xml file:
        <?xml version="1.0" encoding="utf-8"?>
        <Settings>
        <Category name="Samantha">
        <Entry key="Preset" value="General;Default"/>
        </Category>
        <Entry key="UseShapeFromSilhouette" value="1"/>
        <Entry key="UseShapeFromSilhouetteForInitialization" value="0"/>
        <Entry key="ShapeFromSilhouetteLooseness" value="50"/>
        <Entry key="ShapeFromSilhouetteNumberOfBins" value="256"/>
        </Category>
        <Category name="Surface">
        </Category>
        <Category name="Texture">
        </Category>
        </Settings>?
        Here is the build error (Samantha phase runs okay):
        1 2023-03-21T16:17:32.805Z FlowEngineAWSContainer failure. Quitting...
        2 2023-03-21T16:17:32.321Z Generic error
        3 2023-03-21T16:17:32.288Z [16:17:32] Input Sparse point cloud vertices: 73316
        4 2023-03-21T16:17:32.288Z [16:17:32] Cameras: 300
        5 2023-03-21T16:17:32.288Z [16:17:32] --- Settings ---
        6 2023-03-21T16:17:32.288Z [16:17:32] Starting 3DF Stasia...
        7 2023-03-21T16:17:32.288Z [16:17:32] Starting FlowEngine v. 6.010
        8 2023-03-21T16:17:32.153Z Dense cloud generation...4 5
        9 2023-03-21T16:17:32.121Z [16:17:32] 3DF Samantha ended successfully.?
        Perhaps I have too many cameras? I have been sent 300 files to work with, is that too many?
        Thanks,
        Nick
          Since Flowengine failed at the beginning, maybe the camera masks were not loaded correctly. I have to ping Andrea Alessi as I'm not an expert of the aws version. On standard Flowengine, you load the camera masks with the CameraInterface::loadMask or CameraLoaderInterface::loadMasks functions. The number of cameras is not a problem. Also, I noted the version you are using is not up-to-date (6.010). I don't think it would solve this issue, but I also suggest using the latest one available.
          Cheers,
          Roberto
          • nkelsey86
            • Mar 2023
            • 8
            I tried again, this time my .zip file only had 60 image/masks in it (with the same Default.xml settings as above)... I still get following error:
            1 2023-03-21T17:43:41.903Z FlowEngineAWSContainer failure. Quitting...
            2. 2023-03-21T17:43:41.777Z Generic error
            3. 2023-03-21T17:43:41.772Z [17:43:41] Starting FlowEngine v. 6.010
            4. 2023-03-21T17:43:41.772Z [17:43:41] Starting 3DF Stasia...
            5. 2023-03-21T17:43:41.772Z [17:43:41] --- Settings ---
            6. 2023-03-21T17:43:41.772Z [17:43:41] Cameras: 60
            7. 2023-03-21T17:43:41.772Z [17:43:41] Input Sparse point cloud vertices: 19885?
            • nkelsey86
              • Mar 2023
              • 8
              Sorry, I just saw your last comment (thanks again!).
              My file & masks are loaded into the root folder of my .zip file, along with the Default.xml (contents provided above).
              The image files are saved like the following: 0001.jpg, 0002.jpg, etc.
              The corresponding masks are saved like this (in the same directory): 0001.jpg_mask.jpg, 002.jpg__mask.jpg, etc. (<-- perhaps this is the issue?)
              • nkelsey86
                • Mar 2023
                • 8
                I tried this also with mask files renamed to '0001_mask.jpg, etc.' and the process still gives 'generic error' at very beginning of stacia process.
                  • 1377
                  have you tried with .bim images? I'll check, but IIRC FlowEngine cannot load non-bim masks.
                  • nkelsey86
                    • Mar 2023
                    • 8
                    Ok, thanks. I thought in the documentation I found online you can load '_masked' versions of your target files, with black for background and white for target, and the system would use those.
                    It could be outdated or a different verison, but here is what I saw:
                    (bottom line): You may import masks that have been generated outside 3DF Masquerade into 3DF Zephyr using the _masked suffix.
                    Also in this thread it looks like the same advice, even for 3DFlow:
                    Hello Is there somewhere a description of the bim format that is generated for each image with the Masquerade tool? I am asking because I will have to implement my own bim-generator (outside zephyr) for some POC. I assume it is probably simple. e.g. first 4 bytes: bim format recognition string next 2 bytes: width of mask in
                    *I'm probably missing something here, so sorry if it ends up being something obvious...
                      • 1377
                      3DF Zephyr can indeed load masks in that way, but not FlowEngine IIRC. They are two separate products although vastly compatible
                      • nkelsey86
                        • Mar 2023
                        • 8
                        I tried using the 3D Flow example for silhouettes (the bottle example), just to see if I am getting things correct.
                        I created a .zip archive with the '.JPG' files and '.JPG.bim' files included in the sample you guys provide (e.g. 'IMG_0689.JPG' & 'IMG_0689.JPG.bim', etc.).
                        Also, I included a 'Default.xml' file with the following contents:
                        <Settings>
                        </Category>
                        </Category>
                        </Category>
                        </Category>
                        </Settings>?
                        I checked in the S3 ingestion bucket and the folder & zip archive share same name, the files are same name as in the sample provided.
                        Could it be a problem with the 'Default.xml' file? Do I need more/less/different information?
                        Thanks and sorry to take up so much time.
                        P.S. - Is there an example 'Default.xml' that can be run for FlowEngine to render from silhouette on the bottle example?
