Import mesh and alignment from Metashape
  • Mcdoug
    • May 2023
    Hi there,
    Is it possible to import a set of aligned images and an already generated/clean mesh from Metashape? Perhaps this has already been a discussed topic? Id like to try using Zephyr for texturing only. Metashape isn't very good.
    Thanks!
    Will
    I'm not sure what the export capabilities for metashape are, but you can indeed.
    I suggest using the .xmp format, if supported, so you can easily export and import the cameras as they are. Then it's just a matter of also reimporting the mesh and structuring it, then you can create the textured mesh.
