holes in the picture
  • 7erchris
    • May 2023
    Hello, I'm Chris from Germany. Unfortunately I have a problem with the program. I want to make a copy of an item. However, the item has holes. I've tried different backgrounds or lighting. However, the holes remain in the copy. I hope you can help me.?
    Greetings, Chris
    Hi Chris,
    thin surfaces may need to tweak a bit the thickness parameter: try raising it a bit
    Optimizing Thin Meshes   Welcome to the 3DF Zephyr tutorial series. In this recipe, you will learn how to optimize the 3DF Zephyr settings for difficult subject with a thin geometry, such as leaves and other similar surfaces.   Introduction Depending on the … Read More
