How create plan views or elevation views (architectural).
  • Jose M Villar
    • May 2023
    Hello.
    I am testing the Pro version. By default the work window is shown in conical perspective. Can you switch to parallel perspective?
    I need it to generate an elevation view and a plan view of a building model, so that it is in parallel projection (usual in architecture).
    Thank you so much.
    Greetings.
    Hi Jose M Villar - Welcome to the forum! You can change the view-port camera style through the menu system: Scene>Camera>Orthographic Projection... (on/off).
    You can generate orthophotos of the sparse/dense/mesh generations through the Workflow Menu.
    Tutorial: https://www.3dflow.net/technology/do...on-3df-zephyr/
    • DMG
      • Sep 2022
      • 12
      I like to use the buttons on the number pad to change views along the X, Y and Z axes, using 7, 1, 8, 2, 4, and 6, and the 0 switches between perspective and orthographic.
      Cheers
      • sahikha56
        • Jun 2023
        AutoCAD, Revit, Archicad, SketchUp, Photoshop, Illustrator, Lumion, there are lots of programs you can do things like this. just name your poison.
        ? JJSploit
