your recommendations for the texture workflow
  • jupp2000
    • May 2021
    • 85
    Zephyr to Zephyr plus additional textures would be kind.)
    Thanks in advance and keep up your good work at the outstanding Zephyr app!
    Stephan
    Hi jupp2000 -
    It's difficult to make generic recommendations around texturing as there are lots of different ways to present models and different programs have different requirements. For example, in some programs you can use multi-tile textures (UDIMS) but this isn't supported across all programs. I tend to keep to single textures for this reason, as they are the lowest common denominator.
    Have you heard of xNormal? https://xnormal.net/ - It's a free piece of software which you can use to generate all sorts of maps for your model and is a good place to start!
    Here's a tutorial you might find useful: https://www.youtube.com/watch?v=oMUGxUqAql8
    If you have specific questions re: texturing in Zephyr, let us know! Outside of Zephyr it's difficult to troubleshoot but more than happy to assist if it happens to be something I'm familiar with.
    • jupp2000
      • May 2021
      • 85
      Hi cam3d
      yes, it was a bit off topic, sorry!
      I asked about that, because the textures of Zephyr (and probably all other photogrammetric apps) are "as seen by the camera" and not topological unfolded.
      There is a planar texture export function in Zephyr, can i re-import an edited, unfolded texture again in Zephyr?
      Best regards
      Stephan
        Hi again jupp2000 - That tutorial I linked (https://www.youtube.com/watch?v=oMUGxUqAql8?) covers this subject :-) Admittedly it's a little out of date as we have made a few changes since then, but in principle, yes you can export a model from Zephyr, map it in a third party software (like Blender) then re-import and re-texture the model using the new UV map.
        Note: The model has the same scale/rotation/translation when exporting and re-importing so that the cameras all line up nicely to the surface of the model.
        • jupp2000
          • May 2021
          • 85
          That was exactly what i was looking for, thank you!
          Stephan
          • CG-Guy
            • Apr 2018
            • 151
            I use substance painter it can touch up stuff pretty easily
