3df zephyr settings
  • Sayeed khan
    • Oct 2022
    • 23
    3df zephyr settings
    i have 20 gb GPU and 64 GB ddr5 ram
    what parameter values should i set in 3df zephyr setting to make full use of these ram and gpu capacities
    i mean parameters like max points for vol computation / selection / during import
    image cache limit and hardware limits
    Hi Sayeed khan
    The settings chosen in Zephyr depend on the input images and project requirements, I recommend you use the default settings for the initial camera orientation phase, then slowly increase settings as desired in the mesh creation stages. You may find that disk space becomes a limitation at times, so make sure to to plenty of room on your drives when initiating a large project.
    Remember, max settings are not always ideal. It's best to use the general default settings and try to improve your photography rather than mess around with settings in Zephyr trying to make bad data work :-)
