Animation video export flickering
  • Wekedoo
    • Aug 2022
    Hello.
    I have problem with exporting animation video without flickering - or pixel moving. Animation in Zephyr does not have this problem, but exported video does. I tried increasing bitrate but did not help. See here: https://youtu.be/6LaNW0NVxeI. Especially visible in dirt. Am I doing something wrong?
    Win10 22H2
    Zephyr 7.013
    GTX 1080 and 1070
    Thanks
    Hey Wekedoo - My first thought would have been to adjust the bitrate too - If it's still a problem over 24Mbps try increasing the video output resolution - I think the problem here is there is a lot of sharp detail and at lower resolutions (and bitrates) you're bound to get some flickering as pixels fight over which one gets viewed and which one doesn't.
      Hi! Try toggling your "disable texture mipmaps" setting in the system tab option.
      • Wekedoo
        • Aug 2022
        Hi. Thanks for suggestion. This helped a little, but issue was eliminated totally utilising also suggestion by cam3d with increased resolution. Thank you both.
