HELP, Can you combine textures?
  • James.R
    • Jul 2023
    Hi all,
    I wanted to make a 3D model using 3DF Zephyr and import it into unity.
    The model turned out pretty good however, the software generated 4 different textures. This is a problem because i none of them fit my model!
    I was wondering if anyone knew how to combine these textures into one or some other method which would allow me to wrap the model.
    Thanks
    James?
    Hi James.R - When you're setting up your textured mesh generation, you can either use the 'Default Single Texture' preset or you can head to the advanced settings and set the max number of textures there.
