Control point accuracy
  • jupp2000
    • May 2021
    • 85
    Hi folks,
    regarding control points:
    What is more important for accuracy:
    - to get low local and global values between the images, which are used for GCP
    - or to get just visually close to the first point? (and ignore the circle and the epiloar line)
    Best regards
    Stephan
    • 703
    Hi jupp2000
    Both are important to observe!
    Ideally both the values will be low and the visuals should closely match.
    If the values and visuals don't match then it's likely that you have camera mis-orientation.
    • jupp2000
      • May 2021
      • 85
      Hi cam3d,
      thank you!
      I have no problem with low values or
        • 703
        jupp2000 is your subject completely rigid? Or is it possible that the shape changed between the two scans?
